1. An upgrade is pending. The site is only accessible in debug mode.
    Complete Upgrade
pinion seal
Discussion in '60-Series Wagons' started by Southbound, Aug 21, 2006.
  1. Southbound
    Southbound
    622
    18
    Mar 3, 2006
    CA
    So I've already decided to do a knuckle rebuild and am wondering if I should address a pinion seal leak at the same time. I don't even know where the pinion seal is, I just know my mechanic said it's leaking. I'm thinking if I'm taking everything apart anyway for the knuckle rebuild it shouldn't be that much more effort to replace the pinion seal. Or is it? I started reading some of the threads on pinion seals and it sounds like I have to take the whole drive shaft out to do it. I don't know, is it worth it? I just wish I had a better idea what I was getting into before getting into it!
  2. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,442
    1,911
    Feb 17, 2002
    Las Vegas
    Umm, if your pinion is leaking you probably have a bad pinion bearing.
    The pinion seal is behind the flange that the Driveshaft bolts to.
    get under your truck and grab a hold of the driveshaft. Wigglt it back and forth (wiggle, not turn) if it has any play, you need to rebuild your diff. Tightening the nut sometimes works but if you are in it for the long haul, just replace the bearing..
  3. Jan-78FJ40
    Jan-78FJ40
    3,794
    481
    Sep 6, 2002
    the pinion seal is between the input of the 3rd member (differential) and the attachment for the driveshaft (pinion flange). It is not hard to change. Basically, take the drive shaft off (you'll need two 14mm wrenches) on the side of the differential. when that is off, you'll see a big washer'lock nut in there (I think it is 34mm, but I am not sure). take that off, then you can slide the pinion flange out. underneath you'll see the seal. pry it out, and put a new one in. it can be a pain to get the new one in. it helps to have the old seal-put it over the new one, and use a rubber mallet to get the new one in-hammer just on the old one.
    then put the pinion back on, adjust the torque with the lock nut, stake it, and you're done.
    at least that's how it works on my 84.
    hth
    j
    PS. and always listen to Mace!
  4. Mace
    21,442
    1,911
    Feb 17, 2002
    Las Vegas
    Great description
    But that last part is not the best advice ;)
  5. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,373
    Media:
    17
    Albums:
    1
    722
    Oct 1, 2003
    MN
    Does your engine leak oil?
    Do you change your own oil? If so, do you clean up all the oil that possibly leaks from the filter when it is removed?
    The supposed leak could be from other oil, and not the pinion seal....
    More that a couple trucks have come into the shop with the owners stating that the front pinion seal is leaking, only to clean the area up and realize that it is not the pinion seal, but engine oil.
    Just another thought....
    Good luck!
    -Steve
  6. Southbound
    Southbound
    622
    18
    Mar 3, 2006
    CA
    Thanks guys. I'll try that Mace. Do I check for play with the truck on the ground or when it's on stands? Would there be any other indication I have a bad pinion bearing other than the seal breaking?
    I do have a small oil leak and it would sure be nice if that's it. I'll clean up that whole area and see what happens.
    Thanks again.
  7. Mace
    21,442
    1,911
    Feb 17, 2002
    Las Vegas
    A leaky seal is one of the best hints at a bead pinion bearing. So check it to see if it has any play in it.
    BUT, like Poser said, if it is motor oil instead of gear oil, you are fine :)
  8. lovetoski
    lovetoski SILVER Star
    4,543
    219
    Jul 13, 2003
    This might be a dumb question, but did your mech say it was the front pinion seal that was leaking? Most 60's don't use the front drive-shaft much - so is it possible he was referring to the rear pinion seal?
  9. lowtideride
    lowtideride
    7,608
    Media:
    12
    Albums:
    1
    82
    Sep 29, 2003
    The Sunshine State
    If it was the front....Poser is prob. right.
  10. Southbound
    Southbound
    622
    18
    Mar 3, 2006
    CA
    No, it was definitely the front pinion he was talking about. I was with the mechanic underneath the truck when it was on the lift. He pointed in the general direction of the front diff and said "see all that oil and grease mixed? Looks like a bad pinion seal." All I saw was a thick coating of greasy sludge...
    So are you saying 60's don't use the front drive shaft much because it is only engaged when in 4x4 mode?
  11. lowtideride
    lowtideride
    7,608
    Media:
    12
    Albums:
    1
    82
    Sep 29, 2003
    The Sunshine State
    Yulp...Poser was right....
  12. lovetoski
    4,543
    219
    Jul 13, 2003
    Yup.
  13. fliphkd778
    fliphkd778
    990
    5
    Mar 10, 2007
    Okay, so somehow I'm missing the directions on changing one of these out.
    1. Removed axle.
    2. Saw a 30mm nut(most mud threads refer to it being a 32?)
    3. It hardly had any torque at all on it, so I easily removed it.
    4. Then the pinion seal is supposed to be right under that collar?
    5. This is what I saw:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  14. agent orange
    agent orange
    2,227
    7
    Jul 8, 2005
    New Kent, VA
    Thats it, the seal sits in a recess in the end of the third. Stick a little pry bar under it and lever against the opposite side, it will come out.
    BTW, there should be like 200+ foot pounds on that nut. The lack of any preload is why the seal went bad, and probably means the pinion bearing is at the very least worn if not on its way out.
    EDIT: Of course, all of that is assuming it was actually leaking.
  15. fliphkd778
    fliphkd778
    990
    5
    Mar 10, 2007
    Much thanks.
    Yes, it leaks everywhere.
    I've heard that the splined shaft in the photos shouldn't have any play in it? Otherwise indicating a bad bearing?
  16. fliphkd778
    fliphkd778
    990
    5
    Mar 10, 2007
    I don't know about you, but mine's stuck bad.
    I put a big old pry bar in there, but it just bent.
    I better just take of the 3rd....
  17. fliphkd778
    fliphkd778
    990
    5
    Mar 10, 2007
    I know it's been a while, but it wasn't leaking all that bad so I let it go for a while.
    Now I'm back at it, and running into the same issues.
    So far, my axle has been different in several ways, my pinion nut was a 30mm instead of a traditional 32, there was no wire-locked nut as shown in the sor diagram, and my input flange is different too.
    -Can the third just be pulled at once? I loosened all 10 or so around the circumference and drained the oil, but it's sort of stuck coming out
  18. cruiser88
    cruiser88 SILVER Star
    11,878
    Media:
    3
    Albums:
    1
    286
    Feb 21, 2006
    Winston Oregon
    Yes you can pull the hole third at once. Yep it will be stuck fairly good so wuth some elbow grease and a big @#$%^& hammer:D it will come out
  19. exrsa1
    exrsa1
    1,007
    Oct 7, 2003
    Kansas City, MO
    Sorry if I missed something, but you do have the axles pulled out, right? If so, just put a jack under the front of the diff and slowly put pressure on I till it breaks free. It is heavy, so be ready to handle that when it comes out. Also, pulling the diff is not going to make this an easier job to just change a seal.
    Ex
  20. fliphkd778
    fliphkd778
    990
    5
    Mar 10, 2007
    I'm sorry; it seems CCOT sent me the wrong part. The one they sent me was the wrong dimensions, leaving me questioning where it went. The correct one I got from my local parts shop, a National/Federal Mogul #1177. High quality, same as oem.
