- Joined
- Mar 16, 2003
- Threads
- 201
- Messages
- 615
Found my calipers and measured the nut. As Steve (AKA Poser) replied, it is indeed a 30mm nut (or 1 and 3/16 inch). Anyway, after purchasing a socket, fabricating a pinion flange holding tool (tech section), and mentally preparing for a wrestling match ala crank pully nut, It was with mixed feelings as I spun the nut off with barely more than two finger pressure on the breaker bar. WTF, maybe this why I had a leak? Regardless, I'll pull the flange and change the oil seal anyway. My actual question is this: Can I use the nut again, as long as I can torque and stake the nut on a different side of the nut aligned with the groove on the pinion?
Any input appreciated related to the task is welcomed.
Cheers, and keep on Cruising!
Dave
Dave
