Looking at the Pin 7 Mod.
Slee and all the others I have read advise to remove the contact from the ECU plug.
Is this just to do "A Proper Job" or is it required to make the Mod work.
I located Pin 7 and the black wire with the blue tracer and thought to hell with it I will cut it instead.
Now what happend was that I only succeded in making the front locker permanently engage with this method.
I have compared the picture from Slee with what I have on my truck and I am absolutley sure that the wire I am looking at is the correct one, Pin number 7 black wire blue tracer silver marks, the only other wire that has the blue/black marking is either position 1 or 9 depending on which way you look at it!! I have just been to check again and I only have 2 wires that are black/blue on the connector.
I have also compared the photo again and I am sure it is the correct wire.
Now either I "must" remove the contact to make it work or I possibly have different colour wiring there.
By the way it is a 1995 model
On further investigation what I hadn't allowed for is Slees' advice is for left hand drive.
Right hand drive have the transmission relay in the right hand kick panel.
What you find in the Left hand panel is the 4 wheel drive control, which doing this by the light of a torch asssited by half the moths on South Island and a coupla cats, is not the bit that you want!!
Oh well live and learn.
I now have the Pin 7 Mod
