Picture of rollbar hoop flange mount? (1 Viewer)
38.0111,-109.9181
OEM "rollbar" hoop: there is a flange at the bottom where it bolts to the body, would anyone have a pic or a reference to pic so I can remember what the junction looks like?
thxm,
Denver
Although this rollbar is not exactly OEM, it looks just like it.
I've got more pics of my rollbar on my computer at work that I can add tomorrow.
Is this what you're looking for?
Crawlorado.com
These are the ones We make for our fj40 Cage kits.. PM me if your interested in a set! we just finished a die so we can bend them on the Scotchman :D
38.0111,-109.9181
Thanks guys, this helps a lot, gotta go find three hoops.
Quick question, do most folks re-enforce the underside of the body under these mounts?
Denver
I'm pretty sure most have at least a square steel plate the same size as the base pictured. Or you can get short sections of tube to tie into the frame.
Most people on this forum would suggest that the OEM 'rollbar' is not stout enough to protect much at all. Metaltech (metaltech4x4.com) makes OEM reproductions that are thicker but look nearly identical and are not too expensive.
Good luck.
38.0111,-109.9181
Aye, keeping it as stock as possible, and need 3 hoops that go the length of the Troopy and need seat belt attachments. I'll have to check with Metaltech to see if there's anything new.
Crawlorado.com
A roll bar or cage is only as good as the Metal that attaches it to the frame.. and on most of our rigs we are dealing with Thin & Rusty Sheet metal.. We always suggest tieing the Cage to the Frame with a piece of tube plated at the frame and cage
38.0111,-109.9181
My question then though on a flexing bed is exactly that, how much lack of flex, by tying in the bed and body into the frame, will compromise the the body?
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
