- Thread starter
- #21
installing timing gear case
The 3B has indirect injection and the 13Bt has direct injection so there is quite a difference in the head. Not being familiar with the 13Bt but perhaps I am incorrectly assuming it would have different pistons and compression as well. I would then expect the injector pump and injectors have differences also. cheers.
Yep you guy's are correct. I must of had an mid-age brain fart again. The pistons, wrist pins, injectors and injector pump are all different. It's like comparing apples to oranges.
just read this hole thread. Currently I am building up a mitsu 4g63 turbo engine for my ricer. I have alwayse wondered about what to use on the cyl walls and rings when assemblying. Some say assembly lube, some say motor oil, or even atf. Is there a website that has alot of info about putting engines together? I do have some of the sticky lube that you says clogs oil filters. I was told to use it on valve train stuff.
anyone got ideas...?
