anybody out there running 15x10 wheels on 32x11.5 or 33x12.5 tires if so i would appr. some feedback or pics. mayby, ... i no most of you guys run 15x8 but i like the look of the wider stance !!! thx guys .
Exiled said:I ran 15x10's for about three years and *HATED* the way they drove on the road, too much wander for me. Went back to 15x8" during the overhaul.
First picture is 10" wide rims, second is 8" wide rims, same size tires (35").
YODA 88 62 said:the 10in will have a smaller diameter and the 8in will have a larger diameter.
89s rule said:If you want them to be wide then get diff BS 10" are not the way to go from what a majority will tell you on here and any other boards will agree no matter in j**p or what.
10" will loose more beads on the trail. No way around that.
Mace said:A 11.50 tire on a 10" rim will lose a bead easily..
And yes you can get a good footprint on a 8" rim. In fact, it will allow for a longer footprint which helps quite a bit.
11" or 12" tires go for the 8" rim. It is simple. They will handle better (less sidewall deflection) and it will keep the rim edge out of the rocks...
course, if you are looking for a certain "look" then get some 14" wide rims and lower your cruiser for the "deep Dish" look....
