...noticed several threads on this lately and thought I'd post this pic for information purposes.
The interior body molding pops off easily by starting at the rear and gently working your way around. Had it off to silicone quarter panel moulding mount points, rear marker lights, rear window clips etc.
This is what you will see after you get the starboard side cargo panel off. That big black hose is the rear sunroof drain coming down from the C pillar and exits behind the rear mudflap. Ditto on the port side.
Same size lines come down the A pillars in front and drain into rocker panels. I checked mine just for kicks after reading the leak posts and my driver's side was compressed by a mass of electrical wires. Took off the kick panel and cleared the pressure.
The other drains were taking up the slack. No leaks. Cleared driver's side with compressed air and weed whacker line.
