I took a chance on this and the results were amazing. Shipping took less than a week directly from amazon.co.uk by DHL. I installed them immediately and I couldn't be happier.
Yep.I think these are the extended dust caps but, they are sold out right now.
Lexus LX470 LED Bulb Dust Cover Seal Cap Waterproof OEM Design
NOTE: Please confirm your OEM dust cover/cap is the same as one in the above picture, and double-check if the diameter/dimension of your OEM dust cover is the same as this dust cover. If you’re not sure, please contact us for support before purchase, We appreciate it if you could measure the...www.lasfit.com
right above at post #4.Sacman, I want to try them too. Please provide the links the bulbs and the dust covers.
The US Amazon is a little different in color at 5800K vs 6500K to the one sold from UK AmazonPart numbers from amazon would be great. Seems like I need to try these!
I hear you. Between the risk of leaving the cooling fan exposed to dust and the premature life of the LED, it's probably a wash. I'm debating about leaving it exposed as it's protected fairly well from the elements under the hood.Please note that using the sealed covers on the LED bulbs will degrade their lifetimes, especially the high power versions that already require forced cooling. I've seen more laser diode and LED failures due to thermal issues than I care to admit due to improper cooling.
Undersigned,
Your helpful Optics Ph.D.
I've had cooling fan equipped LEDs uncovered on low and high beams for over 3.5 years. No failures from environmental factors; no failures period actually.
