PHH & Tech. Question
SLC, UT
So I did my PHH this weekend. That is a lot of fun. Good times. My neighbor might have learned some new words while I was working in the driveway. :devillook
Anyway...while working on the PHH I noticed what looks like a plug that is right on the engine block, a hanging wire that looks like it should be attached to this plug...but it is broken. I took some pics, cause that will do a better job than describing. Anyone know what this goes to? The wire itself just disappears into a bundle of other wiring, so I wasn't able to trace it to anywhere particular. It seems like it has been broken for a while, I don't think I broke it while working on the PHH.
Cruiser seems to run fine with no issues regardless of that wire/plug being broken off.
Here are pics.
And the wire/plug:
and
Blackgold,
1. Recommend using something like IrfanView to resize your pics to 800x600 or less.
2. Recommend posting your vehicle specifics; especially the year model.
3. I think that is one of the 2 knock sensors. Seems like you would be throwing a code if you have OBD-II.
-B-
Beowulf said:
Blackgold,
-B-
Sorry about that...pics resized.
I'm driving a 1993 FZJ-80 LC.
I'm not sure if I'm throwing any codes, I don't have a reader, but I have no warning lights active on the dash.
Lots of knock sensors have been buggered during PHH exercises. It's kinda in a bad spot...
That is what I am starting to think...spending the afternoon with my nose in the Hayne's manual...the only thing I've found is that it might be is the Knock #2 sensor.
I appreciate the opinion! Thanks!
It appears that this plug effects the idle, as it seems to idle very low now, and even stalled at a stoplight. :frown: And after driving it a bit the Check Engine light does come on.
So...it appears that I did break this plug off changing out the PHH. :doh: :o
I guess if nothing else this can warn others to be careful of that plug.
I wonder how much a Knock Sensor is gonna cost...:frown:
EDIT: No. 2 Knock Sensor = $173.75. Special order part as well, so not kept stocked. Sweet. :doh:
