Petronix igniter question
Hello,
I would like to swap out my points for a petronix igniter II. I have a 76 FJ40 with a 67 dist. There are the two petronix systems the one for the 75 and older is a no go I know but the other one states it is for 70-74. Would the 70-74 work with the 67 dist?
Thank you
Pighead
Stop calling it an FJ
Denverish
Yes. It's the early pertronix you want. The 70-74 also fits the 68 and earlier...
more pertronix
Sorry for the repost/requestion but I am still confused whether the Pertronix setup will work with my rig. Here is a picture of my dist. Looking at that is it possible to determine whether a pertronix ignitor II will be applicable?
thank you for the second shout out. The whole pertronix setup is expensive so I wanted to be sure.
Good day, having more Pertronix trouble. My Dist is the 67 in the above picture. When I attach the plate included in the Ignitor II kit to my Dist. Should the Pertronix plate be able to move or be a solid lock on the Dist Plate?
Thank you
Pighead
Denverish
Mine fits flat and solid on the dist plate...I think that's the way it should be.
Rockingham: Western Australia
Thank you
just be carefull when you screw the trigger to the plate, it dose not jam the breaker plate when vacuum is applied. mine did this and had to shorten those little tiny screws
surfpig
The Anti-Tech
Tagged for removal
I just came back from a run, I remembered this, lifted from Cardinal Fang's website. Might help, might not.
(used completely without permission)
:D
Folsom, CA
Someone used my webpage again:cheers: :bounce: :bounce2:
PinHead says those two distirbutors are both retard distributors. I value Pinheads opinion a lot! He knows his stuff, but I just don't see those two as retards;p
surfpig
The Anti-Tech
Tagged for removal
I do my best thinking when I'm not thinking, and I remembered looking at some of the mods you've done on your truck a year or two back, and remembered your pertronix writeup (the pics). Hope you don't mind.
n
Pighead
Denverish
The octane adjuster is clearly visible in that pic...means it's a '68/earlier vac advance distributor.
