Pertronix install questions
Buxton, ME
Does anyone have a suggestion on how to use the supplied grommet to seal the distributor? This is in a 1976 FJ40. I think it is a stock distributor. 19100-61020
Leave in place (the wire) a ground, remove other part. The black "donut/magnet" will not fit with it on. I think the kit includes a new small wire.
The yellow wire is for grounding the points. The other piece that contacts the cam is the points damper, obviously not needed if you don't have points.
Do you have a schematic of how it should be wired? I am under the impression that with the Pertronix, I don't need the igniter. Do I still need a ballast resistor? If I don't need these, how does the wiring look? I am trying to get a new to me cruiser back up and running, and nothing is connected or marked very well, so I am working off the schematic I found on Coolerman's links: http://www.globalsoftware-inc.com/coolerman/fj40/schematics/FJ40/1976FJ40/1976_Toyota_LC_FJ40.pdf
Now that I have the grommet in, I went to put the magnet sleeve and the rotor on and they seem really loose. Directions say you may need to push magnet sleeve on, but mine just dropped on. The rotor is very loose too. Getting a new one today. Are there any other reasons it would be so loose?
Maybe the distributor is really worn out.
You don't use the igniter. The Pertronix "Ignitor" replaces it.
There's different views on the resistor. My view is, If it's got a resistor (1.5 ohm) it will be mated with a 1.5 ohm coil. (total 3 ohms) A 3 ohm coil gets no resistor. The whole purpose of the resistor with a lower ohm coil is so the resistor can be bypassed when cranking to compensate for the voltage drop and also give it boost since it's only momentary. To remove the resistor from a 1.5 ohm coil, the coil will be at a higher continuous voltage than it was designed for.
If your starter has the extra wire for the bypass and it's functional, I'd keep the resistor. If you don't have the bypass wire on the starter which often happens with a starter replace, I'd ditch the resistor and coil and get a 3 ohm coil.
Hi There! I don't know if i can resurrect this topic but want to dive in with similar questions.
Here's my scenario... I also have a 76 with all of the OEM wiring in place including the starter and its original wiring. My rig has 10k original miles. I recently got it back on the road and wanted to switch to a pertronix set up so I purchased the recommended Pertronix Flamethrower 3 ohm coil and module about a year ago and just getting around to finally thinking of installing it. Id like to keep my factory Ignitor Assembly mounted including external ballast resistor BUT bypass it all if thats whats mechanically best. I want to keep it looking original and simply slide out the OEM NipponDenso coil and slide in the black flamethrower. I read the instructions which seem so generic and simple but when i look at my set up, there's addition leads on the coil, an external condenser and it all spells concern for me!
Any insight is greatly appreciated!
Just run the oe coil...there's no benefits to a "hot" coil, on an engine with a 4000 rpm redline.
Oh! Nice! Should I wire direct to the positive and negative post on the coil? no bypassing the ballast or anything? If thats the case, This will be simple!
(Thanks for the quick reply also:))
Pertronix coils and OEM coils are different diameters, IIRC, the OEM is fatter. Pertronix sells a coil mount just the right size for it's coils. Or, also IIRC, you can wrap the Pertronix coil in something to make the OEM coil mount fit.
Pertronix claims that different ignitors like different Ohms. Maybe this is for a reason other than selling coils.
