Hey folks. First off, thanks for being a great group to bounce ideas off and for maintaining such an awesome repository of info on these trucks.
I bought a one owner 2006 LC with 124k miles and AHC from the same dealer it was originally sold at. It has been maintained there religiously every 5000 miles since it was bought new. I immediately began a baseline and have replaced the following with OEM parts:
outer tie rods
Steering rack
Front Upper control arms
Front lower control arms
Front wheel bearings
Engine mounta
Trans mount
Front and rear sway bar bushinhs
Rear upper and lower control arms
the ride was much improved but I had a persistent roughness and bucking that seemed to come from the front end and despite changing the globes and ensuring the pressures were all within spec the roughness persisted. I finally gave in and swapped the suspension for a conventional OEM setup. OEM torsion bars were not available through the vendor I chose so I used OME torsion bars which is the only non OEM part I used during any of the work I had done. Despite the suspension swap o still have a minor roughness from what seems like the front end. Could this be from the OME torsion bars? It’s a minor annoyance honesty and if I was only driving the vehicle short distances you probably wouldn’t even notice it but I have had multiple TBI’s and any longer drive when I lean my head against the headrest results in a headache. I am literally at my whits end at this point and ready to sell it and try something different because I can’t keep chasing the dragon. Is it worth swapping in OEM torsion bars as a last ditch effort?
Tires are OEM, have been road forced, and are set at proper PSI. I put on KO2s for a period of time but put the stock tires back on to eliminate that as a variable.
Thanks!
outer tie rods
Steering rack
Engine mounta
Trans mount
Thanks!
