- Location
- United States
Looking for a complete pedal assembly. This is the drive-by-wire type which began in '03. Mine is binding as a lot do. New is fine but would also consider used if you're sure it's not binding. Thanks!
Did you find one? Was it a lot better?Looking for a complete pedal assembly. This is the drive-by-wire type which began in '03. Mine is binding as a lot do. New is fine but would also consider used if you're sure it's not binding. Thanks!
Thanks. I'll stop futzing (over here) with the old one then.Yes, I did. I've put these on an '03 and and '05. It solved it 100%.
