98 LX470, 250k on the clock. I monitor real-time with a Scangauge. Background, dealer installed new OEM rack back in Feb and failed to refill radiator. Engine overheated, but I caught it in time (pretty sure). Compression test indicated 152-154 on all 8 cylinders with a very low variance (seemed healthy to me). Dealer installed new thermostat and gasket. At least, they said they did, but couldn't provide me the thermostat they removed (kind of thinking they didn't replace it at this point). Replaced radiator, upper/lower hoses with a CSF back in April and filled with 50/50 Toyota red. Engine routinely ran at 188 since I got it in 2016. I have "rinsed" the radiator and trans cooler with "spot-free" rinse several times the past few months.
Ok, so over the first few months of summer I was noticing that my "normal" operating temp was 190. No real alarms there. It would hold steady at that temp. But, as July arrived and brought the 100 degree days we know so well here in TX, I started seeing the operating temp rise during "load". It would climb to 195 and then drop back to 190 when not on the gas.
Now, it climbs pretty quick to 198-200 when under any kind of load, but drops to 188-190 when coasting. This happens whether it's 107 degrees in the middle of the day or 85 degrees in the middle of the night. The moment I get on the gas at all, the temp steadily rises. I've seen as high as 205 before (long, shallow hill at night in West Texas). I have burped the system a few additional times as a precaution. Required very little coolant (if any).
I drove in CO back in July. The engine would stay 188-190 on steep off-road trails with the engine under load as long I was in 4Lo. If I was 4Hi, the higher temps would manifest.
So, last night, I removed the rad cap (engine off) and coolant was at the base of the neck (as it normally is). The overflow was a tad above "low". I started the motor with the rad cap off and the coolant rose in the neck pretty quick until it wanted to overflow. I turned the motor off and waited 30 minutes for the coolant to drop in the neck. Pretty sure that's normal (though I've read people suggesting taking the cap off, turning on the motor and observing if the coolant is flowing). I check the fan as well. I manually attempted to "spin" it. It would rotate about 1/8-1/4 of a turn before stopping. There was a little resistance when attempting to spin it. Again, pretty sure that's normal and my fan clutch is fine.
At this point, I'm at a loss. I could chalk up the temps to higher ambient for a short while. Heck, I could even chalk it up to the rig being loaded. But, I'm in daily drive configuration the last month and the temp rises anytime I'm on the gas (even just a little). It seems to really spike quick once I hit 55mph. Any speed above that accelerates the temp rise quicker. Part of me is thinking back to the dealer and wondering if A) they put the t-stat in incorrectly (jiggle valve oriented down) or B) they didn't replace the t-stat at all, but said they did (they have a TERRIBLE track record with me r.e. honesty after replacing my steering rack and then saying my coolant was "trapped" in the heater core to explain why there was no coolant in my radiator). Seems odd though that at idle, my engine runs steady 188-190 and fan changes speed from time to time and the aux fan kicks on as normal.
Thinking it's time to completely flush the coolant (5 months old), replace the t-stat and o-ring and then refill again with Toyota Red (mixed 50/50 with distilled water) and then burp the system all over again.
