PCV hoses, too hard?
Discussion in '80-Series Tech' started by GeoRoss, Jul 19, 2005.
  1. GeoRoss
    GeoRoss
    1,952
    1,407
    Dec 4, 2004
    Tucson AZ
    I am in the process of getting up to date on the PM of a new to me 94 FZJ. Before I left for a work trip, I flushed the rad., thermostat, changed the PHH and baselined all the fluids/oils. I also did a tune up (wires, plugs, cap/rotor) to address a ticking in the radio (FM only), which seems to have not worked. Any suggestions on this will be appreciated. I need a new ant. mast, but I doubt that is the cause.
    I also changed the PCV valve. I noticed during the work that the PCV hoses are very hard. Should they be more pliable? I am putting together an order to Dan and I am just curious about how hard these hoses should be. I am sure they are not to pricey, but I'm just curious.
    Dan's dogs are in for a nice treat, this list is getting a bit long.
    Ross
  2. IdahoDoug
    IdahoDoug
    8,864
    272
    Aug 9, 2003
    I got my new PCV hose from Dan - good price.
    DougM
  3. e9999
    e9999 You want to do what...? Moderator
    16,730
    588
    Sep 21, 2003
    US
    cheap enough to change if you are not sure. Mine (surely original) are somewhat squishable. Not hard, not as soft as the coolant hoses.
  4. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,726
    7,588
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    New hoses ave very pliable. Over time they harden into rocks.
  5. GeoRoss
    GeoRoss
    1,952
    1,407
    Dec 4, 2004
    Tucson AZ
    I thought they would be cheap enough to change out either way. Mine are so hard that I didn't know if they are some sort of plastic/PVC or suppose to be rubber.
    Thanks..
    Ross
  6. Hoosier Daddy
    Hoosier Daddy SILVER Star
    954
    196
    Jul 1, 2005
    CO Springs
    Just how cheap are these hoses?
    Mine split the other day.... :eek:
  7. flintknapper
    flintknapper
    5,447
    2,200
    May 22, 2004
    Deep East Texas
    Just changed out my PCV and grommet the other day, and I noticed that the hose was slightly harder than the others but you could still squeeze it. The grommet on the other hand was very brittle and crumbled easily. Maybe Dan can create a "kit" that includes the PCV, Grommet, Hose and clamps. Like he needs something else to do!
    He puts together an awesome birfield "kit" (standard and deluxe I believe).
    Thanks Dan.
  8. Junk
    Junk
    6,177
    31
    Dec 13, 2002
    buggerville nj
    Definitely time to change them Ross. As mentioned, they are cheap - remember to do the grommet too.
  9. santiagol
    santiagol
    108
    Jul 11, 2005
    If this hose is hard there is a good chance your vaccum hoses are also aging, they should all be flexible unless they are formed hoses and are supposed to hold their shape. Fuel hoses are not supposed to be hard either.
    Heat and time will deteriorate any hose - except silicone which is great for some applications (think PHH) but probably excessive for vaccum hoses.
  10. GeoRoss
    GeoRoss
    1,952
    1,407
    Dec 4, 2004
    Tucson AZ
    Hey Junk, I changed the grommet when I changed the PCV valve. Of course it was brittle and broke and fell in and required alot of swearing to remove the pieces with forceps. I didn't notice the hoses until I changed the valve.
    Keep an eye on the mailbox, and no it will not be ticking. :grinpimp:
    Life in AZ is hard on hoses.
    Ross
  11. flintknapper
    flintknapper
    5,447
    2,200
    May 22, 2004
    Deep East Texas
    I'm sure there are a million techniques for removing the grommet without having large pieces of it fall in the cover, but this is how I did it:
    Taped two hacksaw blades together (no tape on the last 4-5") and positioned the blades so that the teeth were facing up when inserted into the grommet. This way you are using a "pull" stroke to cut the grommet and all of the shavings come up and out with the blade.
    Cut one slot (all the way through) anywhere on the grommet and then another slot 180 deg. across from it. You can easily tell when you have gone through the grommet and reached the aluminum cover, so no need to worry about when to stop.
    Unless your grommet is more "crumbly" than mine was, it should come out in two neat pieces by using a pick (or any small curved instrument) to reach down into the hole and pull up on the bottom of grommet. The bottom portion of my grommet was still fairly pliable.
    Be sure to use two blades together... to create a wider slot than just one blade would. Otherwise, you won't be able to move (one half) of the grommet far enough to get it out.
    Whole process took less than five minutes and NO grommet pieces missing in action. Getting the old PCV out is the fun part.
  12. e9999
    16,730
    588
    Sep 21, 2003
    US
    I made only one cut with a blade so that the thing could stay in one piece and I had better control of it without losing the other piece. IIRC I grabbed it on one side with visegrips before trying to pry it off and it came just fine after some convincing. I think I may also have had a shop vacuum going at the same time, but not sure. Anyway no rocket science.
  13. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    My original PCV hoses were hard as a rock. the #2 hose (before the throttle plate) had a 2“ crack where it meets the valve cover, I replaced both of them with bulk hose but the non formed hose takes a wider arc and the #2 rubs bottom of the hood, I probably could have put in an elbow but got the OEM hoses instead, I don’t remember how much they were but it did not seam unreasonable. Besides these, a vacuum hose that ripped when I pulled the TB and the PHH the rest of my hoses are doing OK.
    The new hoses were very soft and pliable when I first got them. They have already hardened considerably in the past few months. This may have something to do with being formed hoses? Maybe it is a hose that takes and retains a shape when heated? They are made differently from all the other hoses.
  14. santiagol
    santiagol
    108
    Jul 11, 2005
    I like the idea of having a shop vac nozzle pulling air out of the PCV opening as this is being done, any small crumbly pieces will get sucked up instead of falling down. Removing the oil filler cap will probably improve the air circulation out of the PCV opening.
