Passenger side lo-beam bulb no voltage
Memphis
Website
128keaton.com
Hey folks, I just swapped my housings out for some glass ones and I went to test the bulbs and found I had no voltage to my passenger side lo-beam. My driver’s side works perfectly, I wasn’t sure if there was a separate relay for DS/PS, but I do hear a click turning headlights on and off. Both fuses showed full continuity, very confused here, but I seem to recall that there is some weirdness with these relays on the 03+ LXs. Any ideas?
Found the EWD and noted that the 12v line is tied to the DRL relay block:
Well, I don’t know what the issue was, but I checked the fuses for a third time after cycling the high beams and I found the fuse for that light blown. Swapped and it seems to be fine now. I have no idea what caused the original issue other than the DRL relay shorting the 12v feed to that light to ground erroneously. No clue, but I got lights:
