Living in the Past
Curious did you ever get the right front wheel to spin? Think you will find converting to disc brakes a lot easier if you can pull the drums off verses breaking things to tear the axle down.
I've been away so I haven't done it yet. I should have some time today to see if I can break it free. I realize now that whenever I drive the FJ after a month or so, the front passenger wheel does hang up a bit just for a second.Curious did you ever get the right front wheel to spin? Think you will find converting to disc brakes a lot easier if you can pull the drums off verses breaking things to tear the axle down.
I raised the wheel and hit the drum with a hammer but it didn't loosen the drum brake. The wheel wouldn't turn. So I took the wheel off to rotate the tire. While the wheel was off the drum rotated. So the brakes are not the problem. I rotated the tire and put the wheel back on. Once it was all together, the wheel would not rotate. So it's got to be the axle. It's not in 4 wheel drive. The passenger front wheel rotates. Anyone ever have this problem?I've been away so I haven't done it yet. I should have some time today to see if I can break it free. I realize now that whenever I drive the FJ after a month or so, the front passenger wheel does hang up a bit just for a second.
I totally feel rear discs are worth it, but wait till the rear brakes need to be done. Rear discs have advantages over drums, but not huge advantages like front discs.
