Parts needed for a v8 conversion
YOWSA....long list....the shortlist goes something like this:
motor mounts, either custom or AA
t-case mount, either custom or AA
t-case adapter, recommend SpaceGhost plate
d-shaft length changes most likely required
Check the AA site for their information on a Cruiser conversion...their motor info is pretty complete, and it's good regardless of what t-case you drop in.
Also, there are 4-5 tech articles on tranny swaps and motor swaps...perusing those will help.
change tranny from column shift to floor shift if needed, Possible modification of cooling system, depending on where you are and how hot it gets. relocate battery, complete different clutch setup, possible weight problems with drum brakes, may need to swap to discs.
[quote author=nspctr1 link=board=1;threadid=5087;start=msg42488#msg42488 date=1063892325]
[/quote]
Good stuff except the weight issue. If he uses a small block Chev he loses a couple of hundred pounds and stock brakes should be fine.
Lots O patience....but well worth it IMNSHO..
