I will be searching for this part (used in good condition) as soon as I know what it is called. It is a cowl or cover for part of the steering? assembly under the hood of my '85 FJ60. 2nd photo is the piece that it covers Thank you!!
Thanks a ton for that! Apparently it's two parts, an upper and a lower. Found a lower on ebay and what looks like both pieces at CruiserParts. Pretty reasonable cost too. I'm on it!I think it’s called a ‘Protector’ maybe but yeah, it covers the yoke where the steering column meets the gear box. This link should help you make sense of it.
Thanks for that info...yeah, the mechanic said it wasn't absolutely necessary but better with than without...It acts as a heat shield for the steering u-joint. When I bought my truck it was missing, and the u-joint was sloppy. Pain in the @ss to install, but it has a purpose.
It might be the biggest pain in the ass in history. Mine is currently on the shelf because I gave up and went without.It acts as a heat shield for the steering u-joint. When I bought my truck it was missing, and the u-joint was sloppy. Pain in the @ss to install, but it has a purpose.
Shoot...looks like I picked the wrong week to quit drinking. Fortunately the used parts were fairly cheap if I have to give up...It might be the biggest pain in the ass in history. Mine is currently on the shelf because I gave up and went without.
Patience. Come at it from the wheel well with the wheel removed. Carefully get one screw started a few turns and then use the second screw to make sure everything is lined up and get it started a few turns once you find it. You do have to do the one closest to the rear almost blind. But just just your Jedi intuition you’ve developed working on that exhaust and you’ll nail it. Lol I’ve gotten good at this... using a box wrench works best. It’s just slow going.It might be the biggest pain in the ass in history. Mine is currently on the shelf because I gave up and went without.
I would hope to have an advantage since the body has been removed from the chassis...plus the motor is out.Patience. Come at it from the wheel well with the wheel removed. Carefully get one screw started a few turns and then use the second screw to make sure everything is lined up and get it started a few turns once you find it. You do have to do the one closest to the rear almost blind. But just just your Jedi intuition you’ve developed working on that exhaust and you’ll nail it. Lol I’ve gotten good at this... using a box wrench works best. It’s just slow going.
