Part and Seek - 1 (1 Viewer)
Kentucky
What is it, what does it do, should it replaced, part number?
vD5gr6DuL128E0Vj3uxmirtUpQ_8NwHb21L_-Rr95C2zySIQXLLcWxpTCFrA6W1lit0aod7bmeudBwtSVj5-ovmzJqm_9sNN0VK6gG9nSFAU8jzXhmNxsi69ay8KxDPFFkDl4AXuvPx_YAmC2_hfM4kdQSbZtgoKdoKvroFalkScPQfOJQKOcL4Rysz_gxJg9WDtLUo-ivQ5xtNbFhyZZ9qEisTonOvid0GOm4YZm1AMCtsTqxBS8fG81HJUdNsFm-FY5rwK2h3xMF_516X3K8UezKF9EQFGPZwYXCGZSFCY7nvP9TJGgqH6YRPi0I9GoYb5VuW5Q9_cloh3ZiBdbUVgsiqyRXnKi6qpTSVYUYSvssKJbnQ2F-z0J8Znf4cR2BzVvJsejl-JDvoHWUG84yOgmqKGRBzFJUre9Z6JmB6N7brlPlhQqnrUnevATBatMT5hpp0s4EnnNBjPyiN2BbtZrugqOYfjFxooRdwMpa2F964MDcmE1ivVlaYAg_NUr_ptfACluAnPlZbr38C783nNdQkXLBp2yQz9M3ID5-vYHrsZ3b8IoYfWdwlXOzDpirnkjEh6dV5aozNPKEBxvL5wOZ63Wva1=w497-h662-no
But it obviously is not doing anything, so why replace it? Or does it work from the sid you can't see?
It holds a spring and a piston that puts tension on the timing belt. Hopefully the inside doesn't look like the out :)
I'd replace when you do your timing belt.
If it is that crusty, it's probably never been replaced. And it should have been. Which means I'd make a safe bet that your water pump, timing belt tensioner, and timing belt idler have not been replaced either, even if your timing belt has supposedly been done. I don't see any marks on the bolts to indicate it's been taken out and put back. I'd be concerned, I would want to pull the passenger cam cover and eyeball the T-belt.
