Parabolic springs, anyone personally have them in a 40?
Northern Minnesota
I've heard about them before and just read the article in TLCA's toyota trails.
Anyone have them in a 40? What did you have before, how do you like them? The concept sounds good?
I've got almost a year old set of Safari springs from Man-a-fre and I think they suck. I realize I'm never going to get it to float on air, but I think they are WAY to stiff. I drive my 40 everyday and use it as a daily driver, looking for mostly the nicest on road ride I can get.
Thanks, Matt
have you tried a search i think there was a writeup or someone has them
i have a set on my 40 i like them, but i need to get new shackles as i have stock shackles that are too short to let the springs do there thing. They ride great on the road and have even better flex off road. I had stock springs before these.
Roger,
I have some more questions, hope you don't get to annoyed. Pretty interested in these things.
What year 40 do you have? Why do you need longer shackles, I thought they were pretty much a bolt on item? Did you get a lift, are there options with the amount of lift you want? Who did you get them through and how much? And, could you tell a big difference from your stock springs to the parabolic's for, "on road" driving?
The last question is my biggest concern. I live about a mile off the pavement on a gravel road and I am looking to soak up the small washboard bumps. Also some of the larger cracks in the road. Right now with my Safari springs I have a pretty stiff ride when it comes to the small stuff.
Thanks, Matt
Matt,
No worries about the questions. I have an E-69 FJ40. There are two reasons why I need longer shackles, first most 40 sit about 1” lower in the rear, and second with more flex the springs need to move more. I was thinking about going with about 1” over stock in the front and 2” or 2.5” over stock in the rear. I would say that they are a bolt on item with the exception that I needed to grind about 1mm off my springs pins, and shackle pins as the pressed in bushings were about 1mm smaller them the pins. This grinding was no big deal. The kit I got only comes in a 2.5” lift. I got my lift kit from Rock Mountain you want to talk with Ray Wood # 1-888-880-2600 http://www.wiseowlparts.com/Catalogue/springs.html The spring are a great improvement over stock. I think that you would be impressed with ride at speed on a gravel road. I love them, but have only been in a 40 with stock spring and a 40 with man-a-fre 2.5” springs and I like them better then both.
I will try to post some pics this weekend I
Got to run
Ian Rogers
also look at this link
https://forum.ih8mud.com/showthread.php?t=17527
Erik Christiansen, Tornadoalleycruiser on Pirate has a set on a 45 and Chef, Alan Loshbaugh I believe has installed a set, too. They are working a deal on a group buy.
They've got all the ditz on them.
Give them a PM or post or search on the Pirate Board.
GL
Ed
Also article in TT last month
Ian,
Do you have the 2, 3 or 4 leaf springs?
Ed,
Thanks for the info on the group buy, PM sent to Chef to see what I can find out? I think I want a set of these.
Need to find a little more info, probably have to email Ray and Rocky Mountain and see what I need?
Matt
What size tires?
Another quick question Ian,
What size tires are you running?
Thanks, Matt
What I've heard. Very flexy and very "comfortable" for an LC. Lift is the question, but those guys know their $hit and will tell you the straight skinny.
GL, and post your results!!!
Ed
Matt-
Leaf springs, and mostly, street air pressure in your tires will not ever give any form of an illusion of a smooth ride on a washboard...
Good luck!
-Steve
2 leaf springs the 3,4 leaf are for the LR. I am saving up $$ to get some 33x9.5 i have tryed 33x12.5, they were too wide to drive aroun with out PS. right now i have 30x9.5 but i know that the 33 will fit with out cutting
Poser said:
Matt-
Good luck!
-Steve
I hear you..... :) But, it just seems like before my resto on my 77 with my stock springs I had a smoother ride? I've got a 72 FJ40 plow truck and that has stock springs and it doesn't seem as harsh going down the road as my 77. There are difference's in tires, 77 with the safari springs are 33 x 9.5's, 72 plow truck are 36 x 15".
I guess what has got me really going on this is that I am helping a buddy of mine currently with a 75 Bronco project (I end up doing all the painting). http://www.crustycruisers.com/bronco.htm Well, he called up the Bronco supply house and talked to there suspension guru's there and got the trick suspension set up for, "On road use". He got some springs made by, "Deaver", anyway I'm getting off track.
Last Friday we installed his brand new springs on the rear end of his Bronco. With just the Chassis sitting there with no engine or body you could put your weight on the rear of the frame and flex the springs, quite a bit? And not your full weight, your feet could still be on the ground. Now a year and half ago when I installed my brand new Safari's on my chassis you could jump up and down on the ass end and not get those springs to budge a 1/4" :confused: . I guess at the time I chalked it up to, the springs were new and I figured with the weight of the body, in time they would loosen up.
Even just now I walked out side and jumped up and down on my reciever hitch, I can get it to move, but not much. And I'm a big guy leverging the weight even farther to the rear now with the reciever hitch?
Maybe I should be asking for something easier like World peace, than a softer ride in my cruiser. :) Just with my buddies Bronco project and the Article I read in Toyota Trails, I thought maybe there is a better set up than what I have.
Matt
Poser said:
What is the difference in spring length between the bronco and the Land Cruiser?
Steve,
I'm not in front of the Bronco project right now, best thing I have at the moment is a pic of them off my website.
http://www.crustycruisers.com/b85.jpg
http://www.crustycruisers.com/b89.jpg
Best I have right now.
I see your point, but.... If the spring length was longer or shorter, wouldn't the springs be designed for the particuliar vehicle? Point being, if they have a soft spring like that for the Bronco, wouldn't they have one that soft for the FJ? One that would flex similiar to that one based on the weight of the vehicle?
Matt
Spring rates vary A LOT from vehicle to vehicle, as do lenghts, which play into the ability to manipulate the spring greatly...
I will measure them tomorrow night, probably won't be able to post the info until Sunday morning.
I will also count the # of leafs, try to make a accurate comparision.
Matt
Longer leaf springs flex better. The leaf springs on a 40 are pretty short. Old broncos ride better than old Landcruisers, partially because of the front coil over set up. Manufacturers do not want to have to replace springs free soon after sale due to sag. So they make stiffer leaf springs. Over time they WILL soften up. Put some bags of "snow sand" (tubular bags of sand, 60 lb each, sold at Home Depot during the winter) , like maybe 10 bags in the rear of your cruiser, more on the high side if you have lean (measure first), then drive it for a while including some rough rutted out dirt roads. This will soften them up. If the rear then sags too much, soften up the front and then maybe some longer shackles in the rear. Should end up with a decent ride. All leaf sprung 40s ride pretty rough, even mine with broken in OMEs.
Yeah they do, and spring configuration varies depending on the intended use of a vehicle and it's design weight both loaded and not. Wheelbase affects the perceived stiffness of a suspension too, and no cruiser will be a Cadillac DeVille.
