Painting Diamond Plate?
Discussion in 'Chit-Chat' started by freightdog, Jul 28, 2005.
  1. freightdog
    freightdog
    861
    54
    Nov 6, 2004
    Lodge Grass, Montana
    I have an old diamond plate truck box - ugly!
    Has anyone ever painted diamond plate? Will it last or just flake off?
    I was gonna paint it flat black...
  2. trainrech
    trainrech
    2,779
    105
    Sep 16, 2004
    Emporia, KS
    If it is Al, you'll need to etch it with (I believe) phosphoric acid which you can get in any autoparts store. Etch, rinse, dry, then prime. Same process as an aluminum tub.
  3. 72FJ40LandCruiser
    72FJ40LandCruiser
    142
    Jun 2, 2005
    If you need to buy some phosphoric acid, check out a local Home Depot. I went to the one in Amarillo a while back and they had changed brands of it and the old stuff was marked $1.00 a bottle, for both the gallons and quarts. I grabbed a couple gallons of it and went to check out. It rang up $.01! I went back and got all the quart bottles and I had already gotten the last of the gallons. I ended up getting 2 gallon jugs and 8 quart bottles for less than $.15. I don't know what I'm going to do with all this phosphoric acid, but you can't beat that deal with a stick! I had gotten around $50 worth of it when I did the math with the original price.
  4. Cobra Jet
    Cobra Jet
    123
    Jul 11, 2005
    Southern NJ
    what I would do is find a shop near you that has powder coating abilities. Powder coating will last MUCH longer than any applied paint. Plus, many shops that do offer powder coating have a multitude of colors & textures now.
  5. stinkyfj60
    stinkyfj60
    1,279
    882
    Apr 22, 2004
    not in stinkyland anymore
    Go to a local parts store and get self etching primer... I dont see why that wouldnt work...
  6. John E Davies
    John E Davies
    915
    89
    Aug 4, 2004
    Spokane WA, USA
    The prep is everything with aluminum - if it isn't blasted or etched to bright metal, the coating will come off.
    I have an aluminum trailer with cosmetic damage from the crappy deicer fluid the city sprays on the streets in winter. I am debating having silver bed-liner material sprayed on it. Can anyone comment on how well that holds up on properly prepped aluminum?
    John
  7. 72FJ40LandCruiser
    72FJ40LandCruiser
    142
    Jun 2, 2005
    You still need to acid etch it. And even then with the self-etching primer you need to get a good two part primer. That stuff in the aerosol can doesn't do a whole lot of good. I figured out while I was in auto body school that a good rule of thumb is that if you don't mix a catalyst with it, don't use it. Like that Bondo brand glazing putty that parts stores sell and everybody uses that just comes in a tube and you don't mix a hardener? Junk... I know some people will disagree with me, but oh well.
  8. elum
    elum
    352
    Apr 4, 2005
    Inland Empire
    Powder Coat!!!
  9. PUPTLAM
    PUPTLAM
    414
    Media:
    18
    Albums:
    1
    2
    Jan 6, 2005
    EAST COAST
    Aluminum is just another metal. Steel doesn't "absorb" primer and paint more than aluminum. Just make sure its clean, prime and paint. I have painted aluminum parts and patches that I have made on aircraft for 20 years, Its nothing special.
  10. TJDIV
    TJDIV Back in The U.P.
    2,063
    Media:
    9
    Albums:
    1
    2
    Jan 28, 2003
    Upper Michigan
    I just painted the s***. It's lasted fine. Who cares if it flakes every six months in "here and there" places. buy two cans of paint. keep one for touch up.
  11. John E Davies
    John E Davies
    915
    89
    Aug 4, 2004
    Spokane WA, USA
    Sorry - if you are painteing aircraft that way you just aren't doing it right.
    I was an A&P mechanic in general aviation for 16 years and I saw many such paint jobs come off in a heavy rain storm.
    Aluminum requires special prep to do a "good" paint job - ie: one that will stay on when you hit it with a pressure washer. Acid washes and epoxy primers are best. Zinc chromate or zinc oxide primers are ok for patches.
    http://www.aircraftspruce.com/catalog/cspages/zinc.php
    John
  12. freightdog
    freightdog
    861
    54
    Nov 6, 2004
