painting body panels
Can someone tell me of a good web site to go to for information on painting body panels? Right now they are raw steel and i was thinking of priming them prior to having them welded on. So hidden spots have some protection. Could use some articles on the subject. I have an auto paint sprayer and compressor. Any advice of similar source for types of paints to look into?
You could and should primer them if they are going to sit out. However, a body shop is just going to sand off the area that is going to be welded so that it is a metal to metal environment. When I sand blasted my panels, I immediately painted on a primer coat. That coat will be sanded anyway BUT it protects it against rust in your garage or wherever.
Acryllic enamel is the factory type on our 40's although for wear it is hard to beat the current 2 stage base/clear systems. There are many sites that have the original colors listed with numbers. As well, it has been discussed here if you search the old posts.
Welcome!
