I just bought new radiator hoses from Dan and installed them (1 upper and 2 lower) about a week ago. While the system was drained I checked the phh and all looked ok, a little bulged, no cracks and not too soft but no leakage detected. I decided to let it ride after reading all of the whining on this board and other places about how hard and time consuming the phh project is.
About 5 days after completing the hoses I noticed a puddle of antifreeze on the garage floor. I assumed it was one of the new hose connections but it turned out to be the phh, must have squeezed it too hard on the inspection.
After completing the phh here are my directions.
1. Remove DS tire, trans dip tube and inside fender guard for easy access
2. Drain engine block of coolant
3. Use dremel tool with cutoff wheel to quickly remove OEM clamps
4. Cut hose off with utility knife
5. Use the old hose as a guide and cut the new hose piece the exact same length
6. Use KY jelly on the inside of the hose to make it slippery (seems to last longer than spit
7. Grab the metal tube and pull it away from the engine as far as you can. This should give you an inch or 2 of extra clearance without removing the bolts that hold it in place.
8. Slide the hose completely on the engine side first and then push the metal tube back towards the engine until it is touching the rubber hose. Now part of the hose should be lined up to go around the metal tube, place a small flat screw driver in this area and rotate it around the tube until the rubber hose is around the metal tube. (kind of like a tire machine forcing the tire over a rim)
9. Now that the rubber hose is started you just need to push(bend) it back into its original place tight against the engine. With the KY jelly on the inside the rubber hose slides easily over the tube as it bends into place.
Here are some things I wasted time on:
1. Calling around to find green stripe, silicone, special clamps ect. No that I have done the task once next time will be a breeze with the std hose clamps in place.
2. Dont bother trying to remove any of the brackets that hold the metal tube in place. Its very hard to get at them and completely unnecessary.
3. No Sears gear wrench needed, I am returning mine tomorrow.
This should be considered a 1 banana job and take 1-2 hours first time around and a ½ hour job there after.
