Painless Dual Battery setup Q's
THE Texas Tech U.
What else is needed other than the battery and tray to install this?
Or other setups?
From a previous thread:
Here you see two batteries. The blue box is a 200 amp isolator (available anywhere) the alternator goes into that isolator as well as the two batteries. The isolator keeps the two batteries charged properly. Now if you look at the yellow top battery you'll see a very large round solinoid. That solinoid (painless wiring) uses a switch on the dash that connects that battery to the other red top battery. The isolator keeps care of both batteries and the solinoid either connects or disconnects the battery from the other. If the red top dies (I left my lights on) the yellow top will NOT be effected unless the switch on the das is ON!
The isolator was around 100 bucks, and the solinoid was 50 some dollars.
TB
prolly have to make your own cables and other odds and ends.
would I need to buy an isolator or does the painless kit skip it with some fancy wiring of that?
Im pretty sure the painless kit doesnt have the isolator. It has that soliniod though.
The isolator is just smart. You dont need 200 amps. I chose that incase I added a 160+ amp alternator in the future for an on board welder.
TB
