Hi all,
I've dug around all (or most) of the AC threads and I think I know the answer to my issue, but wanted to run it by the experts.
2000 lx470, 240k, mostly stock. I bought it in feb 2020 and everything appeared to work fine. In roughly April 2020, I noticed that the AC did not blow cold. I used one of the autozone "pour in the cold" cans with no expectation of a good result, but the AC began working, and worked flawlessly until a few weeks ago. I did note that this past summer, the AC was not as strong as it had been before, but assumed that it likely had a small leak, and that is what had happened originally.
So when the AC stopped working this winter, I assumed that it had leaked out again. However, when I connected the autozone can, the pressures were too high--I don't remember the numbers, but they were in the red with two different gages. Conditions were mid 50s at ~50 feet above sea level.
I verified that the trinary switch is functional and shuts down the AC compressor when the pressure gets too low.
Current symptoms:
65 degrees ambient, 50ft elevations
-No cold air, but the cold hot blend functions correctly--I can get cold outside air and warm air as normal, just no "cooled" air
-AC compressor runs constantly--I observed it for 15 minutes and it did not cycle off.
- All AC lines on the passenger side at the firewall are all ambient temp as well as the lines at the condenser
-No refrigerant observed in the sight glass, but I did see a few bubbles when I was adding refrigerant one time, but then not ever again.
-The AC code displayed on the screen is code 21--solar sensor. I don't think this is the problem, as I don't get cold air when not in auto mode either.
-the condenser fan does not turn on, though I'm not entirely sure that I have met conditions for it to turn on--last I knew, it worked.
- I have not checked high side pressures
The way ahead:
-Based on previous posts, I think I have a blockage somewhere in the system, likely the expansion valve (but I'm not sure about this.)
-This appears to be beyond my capabilities to fix "correctly" as I don't have a vacuum pump, and can't properly evac the system.
-I'll likely take it to an AC shop, but if I can learn anything else useful here, I prefer to not write them a blank check to throw parts at it.
This smells a little like an issue I had with my 94 a few years ago, but in that case, the PO had added some r12 into the system somehow, and the expansion valve was apparently icing up. A new expansion valve, AC dryer and a fresh charge fixed the problem that time--I'm hoping for a similar result this time around.
Thanks all!
Current symptoms:
The way ahead:
Yet another AC question, but slightly different
Howdy, My 94 w/141k is having a bit of a problem on warm days >80. If it sits in the sun all day and I start it up anytime after 1 pm and before 6 or so, the AC will not work . If I drive it for a few minutes and then park it somewhere else for more than about 30 min, upon restart it will...
forum.ih8mud.com
Thanks all!
