Experiencing P0402. I've decided that I don't want to do any of the workarounds, I want to fix it.
Searched a lot of threads over the last few days. Here are some questions, need answers.
I'd appreciate anyone's help with these questions.
- Is the port from the EGR valve to the VSV clogged? - How can I determine this? I'm not sure how to identify the EGR valve vs. the VSV.
- Replace all vacuum lines - Read several posts about vacuum lines that are the wrong size. Is it better to just buy them from Beno?
- I'm told that the 1.5" tube resolves a lot of the P0402 codes - Where is this 1.5" tube they speak of?
- Pull EGR temp sensor and clean with brass brush - Where is the EGR temp sensor? Same as the EGR valve?
- The hardline that goes through the air intake manifold had plugged, cleaned with a piece of non-stranded wire - Where is this "hardline" they speak of?
- Bad cat gasket - Where is the cat gasket?
