Azca
If there is a harder way - I will find it...
Back from a short trip to Northern AZ. On the way up to Flag, the last grade between Sedona off ramp and Flagstaff, I had her in second gear around 4500RPM and she starts to slow and run rough, almost immediately CEL comes on. (and I left my scanner in the Camry
Pull over and shut her down immediately, walk to the front and coolant is pouring out of the coolant reservoir.
Now I NORMALLY keep water in my vehicle on any trip, especially when I am going out into the backcountry. This time I decided to wait until I got to Flagstaff to pick up all my supplies.
So now I have the kids running around gathering snow from the side of the hill that I parked next to and am throwing as much as I can onto the engine and radiator as fast as we can. Luckily I made it far enough north and parked next to a spot that had protection from the sun.
Now after it cools we stick a half bottle of water in it and find the cleanest snow we can to pack the bottle the rest of the way. After about 45 minutes we limp to the nearest convenience store and get bars leak (just in case) and water. Got to an Autozone and they confirm P0306. She is running just fine now...
Now for the question. After putting on another 6 hours of driving with about 200 miles I see no sign of a HG failure and after a day and a half even climbed a pretty nasty 500' change in elevation which required use of the rear locker and in places, the front as well. No foam on the oil cap, nothing odd looking in the coolant reservoir. No water leaks, new radiator, water pump, hoses, fan clutch and coolant change in the last two years. EGR, new wire and just about every vacuum line has been replaced (that I can reach without pulling the intake) have been replaced in the last two years.
Never a hint of an overheating problem driving in Phoenix, even in traffic (max temp I had seen was mid 210s.) The truck is running fine, I lost a little water only because I completely filled the reservoir, now it is at the full line. Spark plugs are less than 6 months old but, are one step cooler than normal, I have been chasing an engine knock...
So what would throw the P0306 and cause it to overheat given the above?
