Afternoon Mud,
I've done some generic googling as well as searched here on mud for possible reasons why I'd be throwing the P0021 code on my 2006 TLC.
This is what I've found so far:
A code P0021 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0021 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is above a set limit (over-advanced), the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft. A P0021 engine code is basically the same as a P0011 code, except this is for Bank 2, not Bank 1.
Potential Symptoms
Most likely a P0021 DTC will result in one of the following: hard starting, poor idle, and/or stalling. There are potentially other symptoms as well. Of course, when trouble codes are set, the MIL (malfunction indicator lamp, a.k.a. the check engine light) illuminates.
Causes
A P0021 DTC trouble code may be caused by one or more of the following:
Incorrect camshaft timing
Wiring problems (harness/wiring) in intake timing control valve control solenoid system
Continuous oil flow to VCT piston chamber
Failed timing valve control solenoid (stuck open)
B]Possible Solutions[/B]
This DTC code is a result of a mechanical fault of the VCT unit or related components, so there is no need for electrical diagnosis. Refer to vehicle specific repair manual to perform component tests for the VCT unit. Notes: Dealer techs have advanced tools and the ability to follow detailed troubleshooting steps, including the ability to test components using a scan tool.
So, the pertinent information:
2006
96,100 miles
Timing belt has not been done - it's on the list but will possibly be expedited now
Truck runs fine with no noticeable rough idle, loss of power, etc. Mileage has been a little down lately ~11mpg in town versus ~12.5 previous. Thanks and I look forward to your thoughts.
Would my problem be fixed if I do the timing belt or would I need to replace/fix anything else?
Potential Symptoms
Causes
2006
96,100 miles
