Oxygen sensor question
I had a engine code 21,24 replaced both upstream o2s. I’m still getting the codes. The o2 harness connectors from the truck are in pretty bad shape. I checked to see if I’m getting any signals from the truck side of the harnesses and I am. Any help? Thanks
I assume you’ve searched, but just incase you haven’t, these threads might help?
“So, I decide to get out the FSM (I know, about time:eek:) Went through the test and the O2 sensor was working fine, but the heater on the sensor was inop. All test indicate the ECM needs to be replaced.”
