I think I might have come up with a way to delete the dvd player and add a bit of organization to the back while camping. Parts are just coming in so it may not work out how I hope. Either way, I thought I’d share as others might find it helpful.
My initial plan is to make a 10 inch by 15 inch cover plate out of .050” aluminum. I purchased a sun visor molle panel that I will install to the plate with some spacers in between the two. I’ve also purchased a cheap LED dome light assembly because I’m too cheap to spend $50 on an OEM unit for the initial trial run.
To get started, can anyone confirm if the white plug with the thin clear wires is the OEM dome light connector? The plug looks right but I’ve never seen wires like that from the factory.
