I'm overhauling my 1FZFE as a result of the head gasket job crawling along with my busy work schedule. 225k, and relative small additional cost will haunt me if I don't. Going to do rings, bearings, timing chain, etc. on lower end.
CAN anyone think of stuff that should be replaced in addition to:
Belts,
hoses (heater, bypass, PHH, radiator),
Stat,
ALL gaskets, seals,
Rad clean / flush / reseal tanks,
Rad cap,
Gas cap,
Oil filler cap,
Night cap,
Day cap,
Noon cap,
bra strap,
Dist cap,
Rotor cap,
Plug wires,
Plugs,
PS pump reseal,
Man-A-Fre ized injectors,
clean injector rail,
vatt, shave head,
Valve grind,
clean cams,
new valve adj pucs,
Alternator brush pack,
Starter overhaul (even though replaced with new one at 125k)
Water pump,
EGR valve,
Fuel filter,
Air filter,
2X Oil changes, (Wix filters)
Various wiring harness repair and rewraping
Powder Coating Air Canister, Valve cover, Charcoal canister bracket, various water pipes, and a few small brackets, all bright Harley Orange. The plug wire covers will be silver with an orange sombrero.
Hopefully a supersharger will follow this job.
I also figure this takes me from a
to a
LC wrencher since I'm doing most the work myself.
Belts,
Stat,
ALL gaskets, seals,
Rad cap,
Gas cap,
Oil filler cap,
Night cap,
Day cap,
Noon cap,
bra strap,
Dist cap,
Rotor cap,
Plug wires,
Plugs,
PS pump reseal,
vatt, shave head,
Valve grind,
clean cams,
new valve adj pucs,
Water pump,
EGR valve,
Fuel filter,
Air filter,
