@GTSSportCoupe
Hello,
Were you able to find one?
Boost controller in front of the map sensor will work too, but it does give an abrupt pressure control (like a fuel cut defender would).
Adjust the spill valve for more fuel, not the fuel resistor. The spill valve tends to add more fuel across the whole power range; the fuel resistor is a smaller amount and seems to have more effect only in the lower rev range. It is day and night difference between the two.
Pop the cap off the spill valve, and mark where it's set. Release the lock nut and turn in for more fuel and out for less. Turn in just a bit at a time (maybe 1/4 turn). Don't turn in more than about 3/4 turn. At 1 full turn, the engine can go into run-away the first time it revs up. You can test this while parked, and be ready to turn the screw out - its the only way to stop it. Sounds scary, but if you're careful, it won't happen. Mine went into runaway and it wasn't too big a deal. You can tell when you're getting close if the revs hang a bit when you rev it.
But if you're hitting 18psi, it's possible your fuel (spill valve) has already been turned up?
Also interested in a bleed valve still.
@GTSSportCoupe can you help us out? Also, I'd like to pick your brain on tuning my 2lte.Also interested in a bleed valve still.
That's forwriting back, after hours of reading on here, I think I'm ready to add some more boost, fuel and bleeder. Found one off ebay.Hi Guys, I'm sorry, I don't have the time to put those kits together anymore, or even post much on mud. There are some other knowledgeable people on mud with regard to 2LTE, and also tons and tons of posts with about everything there is to learn about them.
I hope to get back into it at some point; but next few months are a write off due to work.
Can you share a link?That's forwriting back, after hours of reading on here, I think I'm ready to add some more boost, fuel and bleeder. Found one off ebay.
Yes please! Expensive?Hi Guys I have been thinking about making the electronic version that will self regulate in order to get the 4.0V max out of the boost sensor. This was GTSSportCoupe's idea and its an awesome one! Who would be interested?
Great IDEA! Let me get a few and test them on the bench, I'll let you guys know what I come up withThis is pretty much regarded as a voltage clamp. Not too much rocket science involved at all.
A much more reliable and simpler alternative is get a new map sensor that reads a higher PSI per volt, from memory a Subaru of some sort does the trick.
The existing sensor resolution reads 1 volt per 3 psi. So at 12 psi you are at or around the 4 volt mark.
You can get another sensor, that reads 1 volt per 5 psi. so at max 4 volt input to the ECU, you are running 20psi. I think they call it "3 bar map sensor"
This amount is TOO MUCH.
You will crack heads, blow gaskets, cook the s*** out of it unless you have supporting mods.
Minimum at least have a proper dump pipe and exhaust to pump the heat out.
