You mean those white circle on the pics right?General said:I just noticed what looks to be an Outside Temp Sensor on my 97 FJZ80 located behind the front bumber on the pass. side just infront of the AC evaporator coil. Does anyone know what this is for sure??
wb1948 said:What years come with the outside sensor? And where is there a read out/output?
hoser said:VDO makes outside temperature gauges in both digital and analog. If it isn't compatible with the OEM sensor, VDO has their own sender.
This one is an outside/inside temp gauge.
http://www2.vdo.com/vdo/end_consumer/ec_product_and_fza=_and_ID=617.aspx
I see the fahrenheit version of the analog gauge but not the digital. Guess you gotta ask VDO directly.RavenTai said:Do they have a fahrenheit version?
Rich said:It is used by the auto climate control. No display of temp.
