Builds Outsane/Solvefunction/Cruisin2Camp Build (2 Viewers)
I have similar voltage drop, and have not started pulling fuses yet.
We have exact same dual battery setup.
Ignition lamp control looks good. Unplugged it and I still have the 150mA draw....
My battery has been at 10.3v in the morning and after work.
Solar panel set up starting
Designed / Printed some some mounts. I am going to need to redesign the rears so I can angle the panel from the front easily for more rack storage and to adjust for sun angle.
Rears
What panel are you using? Ive got a renogy 100 watt rigid panel still in the box that I've been thinking about placing up top on my 80. Where are you planning on mounting a controller, and what model?
I've also got a renogy 100 watt solar suitcase kit that I use on my teardrop. I use a trolling motor connector on the outside of my battery box on the camper, so I dont have alligator clips.
Ive got a similar trolling motor connector on my 80, on the drivers side fender. I had to mount it there to try to remove/conceal some previous owner damage-multiplier carnage.
Could you make a flush or at least clean looking cover for the 3rd row seatbelt holes?
