Orion Status
:holdingbreath:
Better to wait, and have it work. Then to install 1 or, "8" and have to pull it out. Or worse, try to explain to customers why you installed it before it was fully tested. Only to send it back.
Does anyone know if this will solve the chronic gear whine I get with the stock 3 speed case? Are they helical cut gears (like a ring and pinion)?
I guess since you need to use your existing input and output shafts that this case will work with an NV4500?
Scott
