i vote for whatever you can run without getting sick .
John Smith said:The only drawback to the Orion is the one low range option. You have super slow and that is it. With the Toybox you have many lowrange options. I normally wheel with just the Toybox 4.7 engaged and the stock transfer case in highrange. When I want silly crawl I engage lowrange in the stock tranfer case. I like the many gear options and find myself using many different combinations depending on the trail.
If you don't want all the gearing options definitely go with the Orion as the install is MUCH easier.
megolfer said:I like the toybox. I have the 2.28 toybox and a sm465. Love the combo because I can use stock low range. Gives me a variety.
John Smith said:I am running a 2F and H41 into 4.7 Toybox into 4speed transfer. I run 4:10 gears in the diffs and 36 bias Iroks. It is driven to all wheeling events and if gas were not so damn high I would drive it to work more often. The stock gears and 36s make for very nice highway RPMs.
Coming from a minitruck background I really wanted dual cases and at the time I bought my Toybox the Orion was still vaporware so the choice was easy for me. If I were to do it all over again I would still go with the Toybox. I still find myself using the stock transfercase lowrange in certain situations but mostly it is stays Toybox or sillycrawl. My one local wheeling buddy with a Orion laments the loss of his standard low range.
76FJ40 said:I'm with John Smith, I really like having three low ranges even if I use 4.7 most of the time. My son did a 3 link in the rear at the same time I installed the ToyBox so the rear axle was moved back 4". I used a skid plate from a three speed 40 and it works great.
