Original F Motor question
Mikesta
Never decruiserfied
Missouri
Website
www.showmerents.com
I have no cash to invest into my motor, but can sell plasma to do it.
From gawking on sites and posts and realizing that these are expensive my hopes are dwindling.
What can I do to cut costs? Like assembly etc? What have others done?
thanks
Having just gone through a 2F, I can tell you that far and away the least expensive way to go would be to locate a low mileage F or 2F. I have a real decent late F I am pulling in a few weeks, but I'm in KC. Look around and see if someone closer has one. Just find out what the oil pressure is and the compression. Plan on a new rear main seal and a timing cover seal while it is out. Guessing you can score one for <$500.
GL
Ed
Restoring a wagon, engine completely apart (how I purchased it). Want to keep the numbers the same.
Well.....
If if needs boring, you need new pistons......$300
If you go with a new cam....$200...regrind....$100
New lifters $110, resurface....a couple of bucks apiece
Bearings, oem, about $200 IIRC for rods an mains.
Cam bearings, let the machine shop install them about $75
Surface head, cut new seats, shot peen clean...$120
Boring...$18/hole, shot peen block, freezeplugs another $100
Grind valves, nothing fancy...dunno a friend did mine.
Toyota gasket set complete, about $225 IIRC
I reassembled mine, with a mechanic friend supervising.
And mine just needed the crank polished, not ground.
New oil pump $140
I don't know where you can cut corners.
Sorry.
Ed
Dont be sorry :)... thanks so much for posting the costs... thats what I'm looking at doing right there. Assembling myself.
I went with a friend last night to pickup his 1 owner old lady owned 78 cherry cruiser with 71k original on it and drove it to his house. I dont care about speed. I want the real thing the way it was made.
Do you take all this stuff to machine shops and tell them what to do? Where should I start? The block?
thanks again for all your help guys
Since you don't yet know if you are replacing the cam, number the pushrods and lifters. I use a little blue masking tape. When you get the cam out you can inspect it for wear or chips. If everything is OK, you can just reuse the cam and lifters puting them back in the same order so the surfaces are mating the same. I did not replace the oilpump, because it was within specs. Also, you might be able to get away with just honing and re-ringing. Get a FSM for the F and some good instruments to measure things, bore gauge, feeler gauge, etc.
That way you will know what needs to be done. The only reason I bored mine was because the wrist pins were a little loose.
.02
Ed
Mikesta, under the addage that life is what happens while you are making other plans, I concur with Degnol on both counts. ;)
You should hunt for another motor now, because they ARE cheap and plentiful AND you will have the benefit of actually driving, using and enjoying your landcruiser while you have the unstressed, patient [read: more economical] project of building up the stock engine.
If you get done with your budget rebuild sooner than you planned, you can always resell the running motor with the obvious benefit that the prospective buyer can hear it running in the truck. If it takes you longer [as is often the case], at least you won't face the prospect of selling an abandoned project that you lost interest in for a loss because it has a big hole in the engine bay.
My .02
