i have a 1980 fj40 found an original boxAll - I have a number of OEM FJ40 Power Steering systems and parts that I have collected over the years.
8/80-85 FJ40. I have the entire system for this vehicle including: OEM Steering box, required short steering shaft stub, tube cooler, pump and high pressure hose. If you have a 8/80 through 85 FJ40, then this is a bolt-in set-up. Very easy upgrade and easily the best thing OEM mod for your cruiser (well maybe A/C). I can also supply the entire steering column, but you will only need it if you currently dont have a column. 100% OEM parts
$1800 for the system
$300 for the factory late model column including ignition cylinder and key
1/79-7/80 FJ40. I also can supply the powersteering components for the 1979-1980 trucks (as above with the OEM Steering box, required short steering shaft stub, tube cooler, pump and high pressure hose). This system is a little different as it uses a single one piece shaft (as opposed to the two piece set-up in the late model). 100% OEM parts
9/72-1978 FJ40. I can supply the components to recreate the OEM set-up in your truck. This is NOT a mini-truck box onto a modified pedestal system. Your stock pedestal will be retained and the most significant addition will be retro-fitting a pump to the engine you are running. Extremely clean, retains the stock chassis components and is easy to send back to original.
$1800 for this system
Please send me a note if you are interested. To be sure, I will want to speak with you on the phone to understand what truck you have and what your goals are.
Thanks. Dave
Dave call me please 732-763-9311Cool. I am assuming it’s a pre-8/80 USA spec truck....correct?
If so, your engine block is drilled for the p/s bracket for the pump. You will need this pump, a pump bracket, high pressure and low pressure lines. A shield and cooler are nice additions as the box is so close to the exhaust. The last piece is a shortened steering shaft. See details on my PS write up for the proper steering shaft length. Otherwise send me a note and we can chat over the phone.
Dave
Thanks. Dave
Hi Dave,All - I have a number of OEM FJ40 Power Steering systems and parts that I have collected over the years.
Thanks. Dave
Thanks for the info.That power steering cooler line is not correct and the power steering pump bracket is on the wrong side, where are you in SoCal?
Hi Dave,
One of the members said you were the master on FJ40 power steering setups. I saw that you no longer supply any OEM kits. My question is that I have a 1982 FJ40 without power steering and I want the OEM fj40 power steering without cutting anything or welding any brackets. Is there anywhere you can find the whole OEM set up with out searching piece by piece. I saw this power steering kit on eBay last night and I noticed the power steering cooling lines were different (not a U Turn shape) The seller told my the power steering box came from a 1976 fj40 and will fit my 82 FJ40. Also he said some of the FJ40s came with this other style of cooling line.
What’s your thoughts?
Thank you for you time.
Sean Sohm
