The vacuum tank is the easy part. Even a small disposable propane tank would work. I 've got a larger old fire extinguisher to put in - once I figure out where. I presume that if you wanted to get fancy and had a big tank, you could wire an electric vacuum pump to start only when the vacuum gets below a certain level - just like an air compressor. From what i understand, the Dorman is running all the time.
