Optima Yellow Top or Pro Comp HDX, which is better?
So my crap for a battery is on its way out and I need a new one. I am going to get either one of the two listed above or just a regular AC Delco Battery.
I can get either the yellow top or pro comp off-road battery, both deep cycle at cost yet the optima is $20 more. I like the pro comp because it has top and side post so I can add cables for such things as a winch if I choose. It also has the top posts positioned near the center so I'm sure my stock cables would be able to reach. Looks to me to be made just like the Exide if not the same (the listing I have of battery suppliers/manufactures do not list Pro Comp). So which battery should I get??
From what I understand, a winch shouldn't be run from the side posts because of extreme current draw. And check the post configuration of both to make sure the battery hold-down system you have will work. Many 4x4 shops now carry the Optima model 34/78 which has both top and side posts (GM style) and forces the batter bar to clamp over the raised part leading to the side posts. I didn't like this option, as it seemed that any abrasion might lead to a short. But then again, maybe I'm paranoid?
I don't think I would buy a procomp battery on priniciple, it is very likely a rebranded battery. There is an Exide xdc (xtreme deep cycle, or something like that, marketed for 4x4, etc.) that I liked in my last LC, it was ~$135.
Well just so you know, every battery is a "rebranded" battery. Check this link:
http://www.uuhome.de/william.darden/batbrand.htm
I would possibly go Exide but it is only the Pro Comp or Optima that I can get at cost.
But just as an update, I think I'm just going to go with the Die Hard International battery. Little pricey at $110 but it's got alittle more reserve amps than the AC Delco I was considering. It's also not a completely sealed battery like the AC Delco but I've always run Die Hards and had good service.
Oh and thanks for the info regaurding using the side posts as hook ups for a winch, read some about it and I guess it's not the most ideal place.
I like Exide through NAPA due to the awesome warranty. Mine was 2 year free replacement and 7 year pro-rate.
