opinions
peoria, az
so i'm standing on a cliff with my bone stock, daily driver, '85 60, pondering the jump to soa, but i've got a few ?'s.
1. other than the hy-steer, what other additional costs am i looking at when compared to say, an ome?
2. i've read that i can run 33x9.5's with no lift, would i still need to re-gear?
3. i would run 35's with the soa, will my stock rims work?
4. i like the look of the 33x9.5's but what kind of availability will i find if in a bind?
your wisdom and opinions are greatly appreciated
Honestly, it doesn't sound like you're ready for the SOA, not if you're still inquiring about 33x9.5's. My advice is to get your self a set of those, wheel your truck, master its cabilities and limitations with that setup, and if you really want to push it to the next level, *then* start thinking about a SOA.
A well-done SOA will probably cost you more than an OME kit, especially if you farm out all the labor. You'll need to address the steering (Hy-steer and ancillaries), make a decision on whether to cut and turn the axle housing (huge debate on this, lots of support for both sides), figure out new shock towers/mounts, get new longer shocks, extend your brake lines and antiswaybar mounts if you want to keep it, and possibly address the driveshafts (depending on your other choices).
If you're going with 35's, you'll definitely have to regear. At that point, you probably want to also start thinking lockers, maybe beefing up the birfields to take the strain. Trails that push you to 35's will also require rocker panel protection, so factor that in, too. Finally, if you plan to wheel hard and use the stock soft springs, you need to think of an anti-wrap solution to prevent pinion damage.
As part of a new buildup phase for my FJ62, I recently (as of last week) priced some components:
$400 for Marlin Crossover Steering (includes beefier tie rods and TRE's)
$360 for two sets of 4.88's
$390 for Longfields and cro-mo inner axles
$220 for two sets of differential rebuild kits
Factor in shipping and taxes and it will be $1,500 worth of parts alone, and I already cut/turned the front axle, already have the two ARB lockers, already have the extended brake lines and front antiswaybar disconnects, custom front shock hoops and long travel shocks.
I did my SOA right and now have 4 years and 50K miles on the conversion. The offroadability of the truck improved dramatically but the extra height did impact its practicality and daily driving capabilities, there's definitely a compromise to consider.
depending on how your stock springs are and the load in your 60, yes 33x9.5's fit on stock.
depending on the state of tune your 60 is in you might be fine with the stock 3.73's. I ran my 60 that way for a year, when I went to 33x10's and swaped gears to 4.10, then rebuilt the carb.......now it flies ;) Prolly if I had done the carb(secondary not working) I might not have done the gears......but I got to add a ARB to the rear :)
avaibliltiy, good question, carry a spare, most places dont stock em.
9.5 is fine on a 6" wheel, 12.5 is not, 10.5 some say is fine, I didn't like it.
the 90 fj62 with stock springs, OME shocks, stock 4.11 gears, no problems with power or rubbing, LOVE em
my 60 when stock with 33x9.5's
now OME with 33x10.5
1.depends on your choices (to do the work yourself or not + parts 500-3,500) :idea:
2.nope. prob not. but maybe. also depends on how you feel about it. ;)
3.stock rims will work if you run a 9.5 and I dont know if they make that kind of a beast (my guess no) :banana:
4. dunno? ;p
Land Pimp if you ever sell a 60 let me know I will fly down from alaska and drive back , good looking rigs
Stock springs, re arched /add a leaf (full length) and 1 inch longer shakcles plus 32X11.50 MTRs, excellent set up. See picture in BDS Kit uninstall thread, this site wont let me upload it again???
Gear ratio/performance feedback?
What gears do you currently have and what differences over stock FJ62..
Drove back through the Grapevine(5S into Los Angeles), and I was pushing pretty high RPM's to get up the hill..
I saw some peoples post about changing gears, wondering what changes I'll see with what gears...
if your not off-roading much and just want good on-road performance out the vehicle what is a good gearing setup for the street and highspeed and steep hills?
