Opinions on quieting ARB Classic Rack
Grove, Ok
Here are some pics of my installed rack. Wind noise at 65plus MPH is fierce. Wanted your opinion on:
1. Does the rack need to be scooted back
2. What bars on the rack should I try to wrap with bungee cord to disrupt wind flow
3. Order ARB wind deflector (I prefer the look without it but would put one on if it would quiet noise
4. Has anyone adapted a simple flat nylon deflector from another brand to fit the ARB
You guys have knocked the cover off the ball with your assistance so I am hopeful you can help me quiet the wind storm. Thanks
Have you experimented with removing the flat panel at the front of the rack to see how much that is contributing to the noise? The air flowing up along your windshield is probably smacking that. You might need to relocate the rack back farther and install a wind fairing to solve your problem.
Spiral wrapping the forward facing bars with the bungie cord to help eliminate vortices would probably be most effective, as the air flow across the rearward bars is already going to be pretty disrupted. That area is also a lot closer to your ear.
I think moving the rack back several inches is worth trying. My ARB is not particularly noisy in the position shown here. Looks better, too.
Move the rack back far enough (do this with the rear hatch fully open) enough so it doesn't interfere with the rear lift gate. Take it back as far as you can.
I know there have been a couple folks here that have wrapped the front bars with rope to break up the airflow and reduce the wind noise. it was @98 SNAKE EATER . You can look up his info in the early part of his threads.
Good point on having the hatch open. Common sense when you think abouit it but something I might have missed.
