Alright fellow Hundy & Luxer's. It look's like the weather in my area is going to be somewhat to my advantage for the next week. So I have decided that next weekend I am going to install my Old Man Emu Suspension kit that I purchased from MetalTech. I've been combing the plethora of knowledge available on this forum, and watching the YouTube video's posted by "BeginnersLuckGarage & OTRAMM" like a crackhead, combing the carpet for something to put in the pipe. My confidence level is good enough to where I feel my neighbor and I can tackle this over the weekend. I will be picking up some tools from Harbor Freight today, and I plan to put her up on jack stands either tonight or tomorrow and start spraying all critical points with penatrating oil 2 times a day until I begin the work next weekend. Here is my thinking out loud.
-Jackstand...what ton/ lbs will I be fine with?
- PB Blaster, or Deep Creep?
- Old Man Emu Suspension Kit w/ OME-860 Medium Load 2" Lift Springs. I have Nitto Ridge Grapplers 275/65/18 tires installed and I plan to keep the front height suspension between 19.5"-21" inches from the center of the wheel hub to fender. Will I need SLEE's Differential Drop Kit?
Toyota Cover Console box
- Pittsburg 8pc Offset Box Wrench set (Harbor Freight)
-Pittsburg 1/4", 3/8" long reach dual flex head ratchet (Harbor Freight)
- 30mm socket
-Brass hammer
-Carbide drill bit for front shocks
-Anti sieze
-Brake grease
-Coveralls & knee pads
-A Classic Rock playlist from hell
If I missed anything, or any of you fellas want to chime in to help make things go alot smoother, I would truly appreciate it.
- 30mm socket
-Brass hammer
-Anti sieze
-Brake grease
