one barrel carb question
Discussion in '40- & 55-Series Tech' started by rgentry, Feb 7, 2004.
  1. rgentry
    rgentry
    693
    3
    Jan 19, 2003
    I have a number of old one barrel Aisin carbs that I am rebuilding
    in order to get one functioning carb. I have some that have a
    big float window and some with a smaller float window. Do you know
    which is the "latter" one barrel carb? There were a few other changes
    in the carbs in the mid 60's, but probably too minor to worry about.
    Thanks.
  2. Landpimp
    Landpimp GOLD Star
    15,908
    Media:
    1
    1,943
    Mar 14, 2003
    Gig Harbor WA
    the small window was the latter, I wanna say it changed from big in 65, to small in 66-7(and early 68) the brass floats(as you prolly know) can not be found but they will swap between big and small window.
    the small window carb also has an idle selnoid, big window(at least mine) doesn't
  3. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,373
    Media:
    17
    Albums:
    1
    722
    Oct 1, 2003
    MN
    Mine on my '65-45 wagon does not have an idle solenoid either...
  4. rgentry
    rgentry
    693
    3
    Jan 19, 2003
    I have a a BIG and a SMALL, both with the idle solenoid. The small
    window does not have the "step up rod", which was deleted sometime
    in 67?? SOR seems to sell carb kits for the early carbs for versions
    with and without the idle solenoid. Who knows?
    My next trick is to find out how my hand throttle hooks up. Thanks
    guys!
  5. Landpimp
    Landpimp GOLD Star
    15,908
    Media:
    1
    1,943
    Mar 14, 2003
    Gig Harbor WA
    will this help?
    [​IMG]
    [​IMG]
    [​IMG]
    this is the 65 large window, stock linkage and hand trottle set up.
  6. rgentry
    rgentry
    693
    3
    Jan 19, 2003
    This helps a ton. What I can't figure out is where your
    accelerator cable is. I see the choke cable and the throttle
    cable, but not the cable from the accelerator pedal. Perhaps
    you have a modified car like FDR used to drive <grin>. Or
    perhaps its here ???
  7. Landpimp
    Landpimp GOLD Star
    15,908
    Media:
    1
    1,943
    Mar 14, 2003
    Gig Harbor WA
    your arrow points to it, its the treaded rod, next to were the hand trottle hooks up.
  8. rgentry
    rgentry
    693
    3
    Jan 19, 2003
    I think I figured out why your pictures don't work for me. Specter shows
    that in '68 Toyota went to cable linkage for the accelerator. So I don't
    have the link I pointed to in your picture. It appears that my hand
    throttle is supposed to hook to the accelerator pedal but I see no such
    provisions for it. At the moment the throttle runs through the firewall
    and lies unattached, in the vicinity of the carb. I bet it used to connect
    there somewhere -- I'll use your photos to see if I can figure it out.
    Thanks Pimp.
