Any SME's in the area of on board air setup. I'm in the process of figuring out my parts collection and setting up a test mount of things on a wood deck in the rear bed of the 60. I think my compressor is ok (don't know until I get it running) its a extreme aire version which on face value appears to be similar in configuration/design as others sold by viair and other mfgs.
So anyway on the output port of the compressor which is only 1/4 NPT , I assume its a good idea to avoid sharp angles on fittings, noteablly anything running from the compressor to the tank (I'm running an external tank too). I was debating on putting a 90degee fitting in the air compressor to make routing of the hot air hose (the hose that runs from the compressor head with hot air, that feeds the air tank ) a little eaiser but I thought that might not be such a good idea. I'll looking to run around 130lb pressure at the air tank.
The install kit from extreme air is lacking and so I'm in process of rounding up parts. Later some of the stuff I do now will likely be trashed, but I want to get the air system up an running then I can make a call on what might be a better approach. I jumped off in this hole and now trying to get things functional to see what really sucks and what kinda sucks. I'll learn from this before I jump on any other parts..not looking for engine mounted air compressors (my ac still works and I'm not going to give that up)
I wanted a couple of things out of this setup (1) run air to air lockers (2) have a port on each bumper or otherwise be able to air up tires off road (3) potentially be able to drive an air tool for moderate use, if needed. This air compressor is rated for 100% uptime. But with only a 1/4 output port....your only going to have so much volume...
