Said I would post when I figured out how I would install the OME steering stabilizer on my Saginaw power steering setup.
I measured and found my tie rod travels a little over 6". The OME steering stabilizer only travels 5", so trying to install it on the tie rod was a no go.
Once I discovered this bit of data I knew I had to go a different route. I examined how the factory stabilizer is setup and then did some research on welding to my pitman arm. The pitman arm is cast steel, so welding with 7018 rod should be fine.
I am fabbing a mount to the pitman arm that should allow me to mount the OME stabilizer in a similar fashion as the factory stabilizer. Got most of the work finished this evening. Tomorrow I plan to mount the factory bracket that I removed tonight.
Pitman arm removed. Plan is to weld a plate on the pitman are that will hold one end of the stabilizer. And move the other factory
bracket over so that the stabilizer will fit.
Scrap steel from an old truck hitch. I will cut a piece to weld to the pitman arm.
Cut this out of the scrap steel plate. Will weld to pitman arm to support stabilizer.
Saginaw pitman arm.
Pitman arm with plate weldeded on. Having the stabilizer end more towards the power steering end means the stabilizer won't travel as far. I laid things out on the floor and I think it will move maybe 4" total travel.
Factory stabilizer bracket I plan to move more to the passenger side.
Test fitting one end of the stabilizer to the pitman arm.Tomorrow I will determine where the bracket for the other end needs to get welded to the frame.
factory bracket will go somewhere over here...
Saginaw pitman arm.
