OME rear spacer (1 Viewer)
Wa
Installed my OME 2" lift a couple weeks back and now realizing I need a spacer since I binned the spring isolator. Anyone happen to have the spacer dimensions for the medium lift kit? Would like to knock it out this week but the shipping for a glorified washer is ridiculous, can probably make my own if anyone knows the dimensions?
Rough dimensions from when I did mine (copy and paste):
"The rear spring center pin is only 15mm OD, but the rear axle has a 25mm ID hole in it..."
Hope that helps.
- Brian
