Going to be completing a OME 2” lift here soon.Does anyone have a recommendation for replacement pads that go between the leaf spring and axle if the stock ones are shot?
70 series Landcruisers don’t use rubber pads under the springs — so it’s not like they’re mandatory. That being said - I always reused mine with newer thicker spring packs and never ran into any problems whatsoever – even after hundreds of thousands of miles and thousands of miles of Baja 1000 roads.Going to be completing a OME 2” lift here soon.Does anyone have a recommendation for replacement pads that go between the leaf spring and axle if the stock ones are shot?
The pads must not be used with OME springs. It is not safe to use them. Lots of threads on this.Going to be completing a OME 2” lift here soon.Does anyone have a recommendation for replacement pads that go between the leaf spring and axle if the stock ones are shot?
The ubolt nuts shouldn't bottom out on the threads. In the stock set up the nuts clamp against the hat channel. The hat channel's sole purpose is to keep the ubolts from over compressing the rubber isolators. With a non-stock spring thickness the hat channel cannot protect the isolators.70 series Landcruisers don’t use rubber pads under the springs — so it’s not like they’re mandatory. That being said - I always reused mine with newer thicker spring packs and never ran into any problems whatsoever – even after hundreds of thousands of miles and thousands of miles of Baja 1000 roads.
The key to reusing the rubber spring pads is ….. ignore the torque spec for the u-bolt nuts in the manual.
That torque is only valid for the stock thickness springs and original u bolts.
At 90 ft lbs (spec) and original springs, the nut bottoms out on the ubolt threads and can’t screw down any farther. That’s where the 90ft lbs comes from.
If the nut doesn’t run out of threads on the bolt because you’ve got thicker springs, youll be cranking down till kingdom come — and fully destroy the rubber pad… and still not hit 90ft lbs.
This is especially true in the front. If your new springs are thicker, youll bend the upper spring perch on the axle housing trying to reach 90 ft lbs.
Bottom Line: DONT TIGHTEN UBOLT NUTS TO 90 Ft Lbs!!!
Don’t even use a torque wrench. Just use common sense.
Thats correct for the rear springs.The ubolt nuts shouldn't bottom out on the threads. In the stock set up the nuts clamp against the hat channel. The hat channel's sole purpose is to keep the ubolts from over compressing the rubber isolators. With a non-stock spring thickness the hat channel cannot protect the isolators.
So what I am hearing is that on my 1985 60, I should not use any rubber (stock or otherwise) and should also discard the hat channels as they are no longer needed eithe?
The front springs’ ubolt nuts bottom out on the end of the bolt threads on stock springs. That’s when the 90 ft lbs suddenly clicks off on the torque wrench
Thanks for the info. So where do I buy the bushing? I bought the kit from CruiserCorp and it is not part of it.Correct, when installing a non-OEM thickness spring.
The additional steel bushing is required when not using the rubber isolators to keep the axle from shifting on the spring pin.
It’s ARB part number CBS01 I believe. @cruiseroutfit should have them.Thanks for the info. So where do I buy the bushing? I bought the kit from CruiserCorp and it is not part of it.
One of the four springs arrived today, and appears to have the center bolt already installed from the factory. Guessing I won't need the CBS01. Thanks for the information.It’s ARB part number CBS01 I believe. @cruiseroutfit should have them.
The center bolt is there, but isn't wide enough for the hole in the axle plate. Take a look at the two - the center pin is maybe 1/2" and the hole in the axle plate is closer to 1". The spacer makes the pin fit in the hole without shifting around. Originally the metal "channel" that held the upper rubber isolator had a round protrusion that served the same purpose. Eliminate metal channel ... get CBS01.One of the four springs arrived today, and appears to have the center bolt already installed from the factory. Guessing I won't need the CBS01. Thanks for the information.
Okay so I bought 4 of those. Is there a torque rating on them or just get them tight? Also I saw some debate about the 90 ft/lb on the u bolts. If I am removing the pads and plates, should I go to 90 or will I run out of thread most likely?The center bolt is there, but isn't wide enough for the hole in the axle plate. Take a look at the two - the center pin is maybe 1/2" and the hole in the axle plate is closer to 1". The spacer makes the pin fit in the hole without shifting around. Originally the metal "channel" that held the upper rubber isolator had a round protrusion that served the same purpose. Eliminate metal channel ... get CBS01.
Also recommendations on rubber grease for the bushings and grease for the greaseable shackles?
OME part number CBS01 doesn't need tightened. Put it where it goes and assemble the suspension.Okay so I bought 4 of those. Is there a torque rating on them or just get them tight? Also I saw some debate about the 90 ft/lb on the u bolts. If I am removing the pads and plates, should I go to 90 or will I run out of thread most likely?
Where are you buying a suspension kit from doesn't provide all of this information for yo
Not to get tribal about it, but I bought a full OME kit from @cruiseroutfit a few years back. I ran into some oddball issues like the CBS01 spacer (my year of 60 shouldn't have needed it, but did). He and his crew walked me through it all over the phone, mailed me parts, etc. @reaton is the place you bought the suspension from not answering your calls or something?
