OME Dakar question
Hey guys- My cruiser needed suspension badly and I decided to go with the Dakar set up. Now that I'm done, the rear sits about 1.25 inches higher than the front. I don't expect to carry a huge load or tow anything anytime soon, so is there anything I can do to decrease the height gap or should I wait for the springs to settle?
Interesting. I will be installing one of these in a couple of week on my friends Cruiser after we pick it up in Boise. Getting the kit from Urban and would like it to be level instead of raked.
In stock form the OE springs have the same rake. Part of it comes from the fact that the rear shackle is longer than the front shackle. Part of it is that the front of your rig is heaveier than the rear.
Yes it will settle in some, and will do so faster if you get out and flex it a lot.
From what I've seen most of the OME kits end up being racked(not slightly either). There are ways to level out the ride but it involves shackle swapping.
Cahil
think you can use the rear shackles on the front to help the rake. Or maybe take a leaf out of the rear or add one to the front. Or wait a bit and it will drop a bit, but not all the way.
I'm still about 1.5 - 2 inches racked on my truck. Doesn't bother me but definitely not level.
I thought about swapping the shackles but there's an 1/2 inch length difference between front/rear so swapping would only change rake by 1/4 inch ?
Cahil
It is normal for all OME suspensions to sit rear high unloaded. It will drop down some with use but the rear springs are a stiffer rate than the front. Swapping shackles will help some but when you load it down the rear will sag instead of being level which can effect how it handles.
I usually tell people to drive it a while then just get used to it.
